i have fitted over 200 remehas with cm907/927 and have only had a handful of problems.
At last! Someone with the experience I asked for. What kept you so long?
I always alter these to 5min minimum on period and leave the the number of cycles to 6.
But that's 50% of the 10 minute cycle time. Do you change the Proportional Bandwidth to prevent overshoot?
The remehas intial fire rate is 2000rpm to start with (about 5 secs) before dropping to the 1300 rpm from where it start to ramp up
I agree, having watched the nF parameter while someone turned the thermostat up. According to a email from Remeha the startup speed (P20 = 25 or 28 ) is used while the boiler is igniting to ensure reliable ignition.
as required to maintain a 10 degree differential on the flow and return. (Which has been changed to 15 degree differential on boiler from july2010)
I would have thought it was required to maintain the required flow temperature. The differential depends on the flow rate, which is controlled by the pump speed and pressure loss round the circuit.
The differential depends on which version of the installation manual you read! The one which came with my boiler says 11C recommended, 15C max; the downloadable versions from Remeha (and on Baxi Partsarena) say 11C recommended, 20C max).
The only problem running at a 11C differential is the very high pressure loss across the heat exchanger (4m on the 18V), which could cause problems with the normal 5m head pump. Increasing the differential to 15C reduces the loss to 2.5m at full output.
The change made above was due to problems with very big systems and large cylinders with 20plus kw coils which would cause the system to take a long time to heat up as the differential would remain often with 40 flow and 30 ish return temps.
Presumably this was because you were wiring up as a standard Y or S plan.
The way round this is to wire as a HW priority, as in Wiring Option 4:
Connect a V4044 diverter valve the "wrong way round" (A to cylinder, B to rads) to X5
Connect cylinder stat to X9/3&4
Connect CM9XX to X9/7&8 (volt free, i.e no link from L to A)
Link X2/1 to X2/4
Connect HW timer to X2/3.
On systems like these the software can be altered but they won't give the code out to many people. Or you can get around it by changing the minimum fan speed to 2000rpm
Do you mean the code to get into the "installer only" parameters?
