Having had to get an electrician involved to replace my CU, as per advise from here and everyone jumping on my back, here is my experience with the so called electrician that came around:
Arranged for my CU to be replaced at the cost of £250 provided I supplied the CU and breakers and ...
CU is a MK item, with no breakers/MCBs/RCDs at all,
Set of Schneider Electrics MCBs/RCDs different ratings based on the advise from him as what I needed
He turned up. Got the feeling he didn't really want to do the job as he had already rescheduled it once.
Anyway, turned power off,
Took the front off
Then said to me that the tails from the meter to the CU were not big enough and needed upgrading. These are 16mm tails.
My current setup is as follows: From Meter to Fuse, then from Fuse to a Voltlage operated breaker, then from the breaker to the switch inside the CU. Meter was replaced by the board about 4 months ago and they upgraded the internal fuse that was installed at the time.
So anyway, he said he can't replace the CU as the tails need replacing and since it is the tail from fuse inside the meter cabinet to the CU, he can't touch it and it has to be the board. he would raise this with them and get them to come and replace and then he would replace the CU
As he was there, I told him I wasn't happy with my electric shower being connected to an MCB and would rather that was connected to an RCBO to give me better protection. He then went and bought an RCBO and came and replace it. At the same time I asked him how much he would charge for a EICR and he said he charges £50 for the report and with the RCBO he would charge me £100 for it all
I agreed, and he proceeded to do the test. Which took him about hr and a bit. He then took his money and said he would send me the report and certificate
3 weeks went past and I didn't get anything from him.
So emailed him and he said that he wasn't happy to send me the EICR as he had come across an issue in his report to do with the bonding to the earth spike outside my house.
As it is a TT install, obviously I supply the earth for the installation. And as it was, the boding used a 6mm cable at the moment and he said this is not adequate and needs to be replaced with a 10mm bonding to the spike and unless this is done he is not going to send me the EICR.
I emailed him back and explained about my understanding of the EICR that it is a report and not a certificate as such which gives me details of any issues with my installation.
He then didn't come back to me and wouldn't respond to my emails.
Having send him a final email and explaining that I will be taking this matter further if he doesn't come back to me with an answer, he emailed me back saying:
He will send me the EICR report soon
He has said that the boding needs replacing as this is a fire risk at the moment as it is using 6mm cable
He now says the 16mm tails are ok and don't need replacing.
He says he wasn't happy to replace the CU as the CU and the breakers have to be the same make, according to BS 7671 2008+A3
So I get a feeling that I have been taken for a ride and would appreciate your feedback as regards to :
1) If he says boding is a fire risk, then should he have replaced the MCB with RCBO as he has made alterations to my CU/installation by doing so, or should he have left it untouched and simply said no can do.
2) Is he right about the CU and the breakers? My understanding is that you can't mix and match the breakers inside the CU but not that the CU and breakers have to be from the same manufacturer?
3) the house is a bungalow at the moment with only 2 bedrooms. But there are plans to extend to 4 bedrooms and turn into a house. He now says the 16mm tails are ok for the current installation, but when in future, we are talking about perhaps 12-18months time, when I come to install new circuits, the 16mm tails are not good enough.
I shall await the EICR and see what it says, I can then check with NICEIC to make sure he is indeed registered with them as I can smell b***** in some of the things he said.
Took the front off
