Was initially 3, to match the one it replaced a few weeks ago. Now it is on maximum.What settings the pump on ?
This did not make a lot of sense to me but, as it was easy to check, I tried it anyway. Max temperature was reduced from about 60C to 56C. So I returned the pump to max.Obviously don't know size etc of your system but try knocking pump to 2. Had a similar problem on a glowworm cutting off at 52deg and showing f22 I think it was...ignition temp too slow or something along them lines. Glowworm pushed for either new pump or heat ex, pump was fine but running at 3 so knocked down to 2 and never heard back so gather it worked, was about 6 months ago.
What filter do you mean? That last picture was the old system. It was all removed in 2005 when the Viessmann was installed. My Magnaclean has been checked with every flush.Get that filter opened up.
Thanks Tony. I presume you use DS3 on components separately and DS40 for a running system? Have you found it effective when used without a powerflush?My experience is that virtually all blockages have been at restrictions, namely connections onto boiler HE, pump valves and motor valves etc.
Also I have found sulphonic acid [ DS3 ] will often dissolve blockages not treated by citric acid.
Tony
Oh dear - not much good if my boiler is struggling to reach 60C !No, I use DS3 in the system water.
But it is not very soluble and needs to be at about 60 C to start to dissolve much at all.
Tony
It is a good point, but I have mains flushed it six times, so I hope that forces out air every time. I was not able to find how to bleed this boiler in the installation and service manual anyway.Mike, how sure are you that the boiler heat exchanger is clear of air?
I watch it sometimes - it keeps me on my toes.I was wondering if the air disasters TV program is must see for you or too close to work to interest you? Its my favourite one.
That's a very kind offer. I will bear it in mind.If you get stuck then you could always call me on my mobile number.
Tony
There is no mention of clearing air from the heat exchanger in either the installation instructions, service instructions or fault finding. Nor is there any mention of filling the HE. Are you familiar with the Viessmann 100c and clearing/filling its HE? Or does anyone else know?It is not just flushing in the sense of making the water move.
But it needs a very good fast flow of perhaps 15 litres per minute plus to drive any air forward.
Tony
