Rotovator Magneto
2 Feb 2009
South Tyneside
I've been given an ancient rotovator - no identifying markson it whatsoever. It's a 4 stroke and it all seems in good condition, not seized etc, but there is no spark and a resistance test on the magneto the shows it is kaput, although it does seem to throw some voltage out 3 or 4 volts maybe. I have no clue of the magneto type - is it okay to just bang any old magneto that fits on there from e.g. a lawnmower?
We’ll need pictures of what you have, I’m afraid......I’d guess you are dealing with a flywheel with contact breaker points underneath?
John
John
Hi John. Yes, that is correct. Here is a picture of the magneto itself - the exposed wire I pulled out of the flywheel. I'm getting 2.62 reading on the earth wire, zero on the body.
At a guess, I'd say that was an early Briggs and Stratton ignition coil, though Villiers did use a similar item at one time.
If the machine has contact breaker points then it is these that sets the timing - they are opened and closed by the cam underneath the flywheel.
I'd think grafting on a modern igniter (which is solid state) would be pretty difficult to get the timing right - but of course I've never tried it!
At least you would need an igniter that matches the flywheel diameter.
I think a good way forward would be to try to replace that coil like for like if you can.
There are probably a few vintage machinery dealers about.
A few more pics of the motor may help us with the identification - and for sure this is an interesting project!
John :)
For sure, that’s an early Briggs horizontal crankshaft engine....many applications, including the Baromix mini mixer.
John
I’ll edit, it’s for around a 2hp engine, seen one on eBay for around £17 I think.
J.
A new one on me......useful bit of kit!
It doesn't do away with the coil though, but fb may be interested in that.
John :)
John :)
They do rely on the old coil, you can remove the points or just cut the wire to them . Iirc they originated inAustralia
and came in plastic, blue or green to suit different engines, even supposed to have some sort of built in advance but I may have dreamed that one. They were so useful to get rid of the points on villiers engines fitted to machinery that wasnt used that often to guarantee a first time start
I think i will see if I can remove the flywheel and see what condition it is underneath before I decide what to do. That no doubt will be a task in itself. There comes a point where, if it's not a hobby, you are throwing good money after bad.
Is this the one?
John :)
It looks similar but without a part number it's stab in the dark. Might be worth offered a tenner perhaps. Not sure how the seller reckons it's in good condition - there's no mention of any resistance testing. :unsure:
I have located the engine as part number 80302. Here is the parts diagram on the Briggs & Stratton website. I appear to need part 298502 (points and condenser) engine? Not the part 389593/591420. 50 quid new :eek:
Remove the flywheel first... there’s a good chance you won’t need new points.
Undo the flywheel nut, but don’t remove it. With a couple of wedges under the flywheel against the solid engine block, a sharp tap with a jammer on the flywheel nut should break it free from the tapered crankshaft.
John
