There's no such thing.external trunking that looks OK on residential brickwork?
Not sure if this is the one but it seems to require 70mm...The minimum bend radius I have for WF100 is 40mm but it does vary depending on the manufacturer ( Belden type H125 is 40mm )
If that two-fold difference is dependent only on the materials used for the foil and sheath, doesn't it beg the question as to what this 'minimum radius' is actually all about?If the foil is aluminium and the sheath PVC then the minimum bend radius is 35mm ..... If copper foil and PE sheath then it is 70mm
I realise that, but I thought (maybe wrongly) that the rule of thumb was that one should not expect/try to get a bitrate much more than three times the bandwidth - i.e. something like 300 Mbps for a bandwidth of 100 MHz for cat5/cat5e.Umm.. xMhz bandwidth ≠ xMbit data rate.Unless I'm misunderstanding, that seems to suggest a bandwidth or 100 MHz for cat5/cat5e and the highest bandwidth for any twisted pair cable (Cat8) as being 1.2 GHz - which is roughly what I would have expected.
It is absolutely pointless to install Cat7 cabling to get to 1Gb.
Cat5 will do it.
If you look back through this thread, you'll see that I have acknowledged that cat5 cable is used, apparently successfully, for 1 Gbps - but that I am amazed that this works over any significant distance (particularly with some of the terminations used) and feel that this speed must be 'pushing the limit' of the capabilities of cat5/cat5e cable.http://en.wikipedia.org/wiki/Twisted_pair#Most_common_cable_categories
. and also wonder whether (and, if so, why) anyone really needs such a speed in a domestic environment.
I suppose that could be one reason - but it's hardly a common domestic requirementUploading simultaneous HD CCTV signals to a NAS could be one...... and also wonder whether (and, if so, why) anyone really needs such a speed in a domestic environment.
I have such a network, with the server serving about a dozen computers in a very large house, but 100 mpbs seems to do fine for that, at least for me.I plan to setup a gigabit network in my house as I'm looking have a central server and pull files off it.
Kind Regards, John.
True, although multichannel HD CCTV must be pretty rare domestically.More and more homes are now getting CCTV though.
I can't argue with the concept of having a somewhat future-proof infrastructure - but, as has been said, properly installed cat5 cable is theoretically OK for 1 Gbps, and it would be reasonable to instal to that capability (with tthe future in mind, if nothing else).I think the point is if you're going to go to all the expense and hassle of fitting a network system, seems silly to not go that little bit extra and make it gigabit compliant.
If you frequently have to move files that large, then maybe you do have that need, but I'd suggest that is also a pretty rare domestic situation. After all, with a network actually functioning at just 100 Mbps, one can theoretically shift at the rate of about 100 MB every 8 seconds, which is good enough for most people. Furthermore, as I said before, I wonder how many 'gigabit installations' actually achieve anything like that speed in practice; as Bernard has suggested, with imperfect infrastructure, and the consequent need for a lot of error correction (or even auto-switching to lower speeds), 'more haste can mean less speed'!I often tend to work with files of the 100s mb size so at non gigabit speeds would take forever and like I said, seems silly not to get the most out of the kit you're installing.
Whilst it may well be true that nothing is actually sold as 'exterior trunking', there is obviously any number of ways that one could cover/protect/'hide' cables on external walls.No-one has contradicted you B-A-S... no... so thanks for the wisdom. I suppose I should route on the inside if possible until up out of harms way.There's no such thing.external trunking that looks OK on residential brickwork?
