P
Paul_C
I can recall repeatedly hearing that we were 'approaching the limit' of transmission speed that would possibly be achieved over the PSTN's twisted pairs.
Indeed, that's been an ongoing thing for a good few years now, then some new modulation technique is applied, or a new encoding method evolved due to faster processing etc. and a whole new land of faster speeds opens up again, until the next time we're "approaching the limit."
I'm sure that many youngsters wouldn't consider my 1.2Mbps DSL connection especially fast, but when I consider the transmission speeds available to me just 10 years, never mind 20 or 25 years, ago, I still find it amazing that technology has progressed to the point of allowing such a high data speed over 5 miles of varying quality cable, the bulk of which in my case is now almost 50 years old.
When I was using 110 and 300 Baud (bps) modems (I guess in the early 80s), the limit was said to be 1200 Baud. Then 2400 and, if I recall, a particularly strong belief that 9600 Baud (0.0096 mbps) was probably going to prove to be the 'ultimate barrier'! Admittedly, although it certainly wasn't the case when I was using 110/300 Baud modems
It was a common misuse at one time to hear and see baud and bps used interchangeably, but they're not actually the same thing. The baud rate is the number of discrete signals sent per second. It will correspond with the bit rate only if each signal carries a single bit, as is the case with the once-common 110 and 300 bps/baud modems.
The 1200 bps modems such as the Bell 212A or V.23 types are 600 baud, but 1200 bps since each signal carries two bits. The 2400 bps speed was achieved by keeping the 600 baud rate but encoding four bits per signal.
only 10 MB (i.e. 0.00001 GB for the benefit of the youngsters!).
I think you're getting a little carried away with the zeros there John!
10 MB = 0.01 GB
0.00001 GB is just 10 kilobytes.
