The purpose of the compound would be to completely water and moisture seal the terminations inside the conduit box. Without it you would be asking for trouble, if you choose a conduit box as your chosen termination box.
Internally he's used crimped connections so inspection isn't really required at that point in the future.
Protects electrical connections from moisture and corrosive vapours and is widely used in a variety of electrical applications including work on junction and conduit boxes.
It possesses good insulating properties and helps to prevent short circuits due to dampness.
It is non-hardening and does not shrink, crack or peel thereby allowing the compound to be readily removed and replaced safely by hand.
