Semi-chased cables in kitchen - is this allowed?
A quick update - the electrician has come back tonight to say it's quite common to have to finish off after the kitchen has gone in and before the worktops, so he'll be out tomorrow to complete the raggling.
Cheers
Does the horizontal run between the two sockets not comply with 522.6.101 (v) ?
Regards
Uhm, see what you mean (I think) - vertical run of cables to small gap between sockets.
Regards
Should be ... covered by a protective metal cover (top hat)
Why?
That's not even up to bodger standard of workmanship
This saves chasing out too much of the wall,
In other words it's lazy.
and also prevents the possibility of concealed cables out of 'safe zones' getting drilled through.
Here's another idea to prevent that.
It's called doing it properly and not having any concealed cables out of the zones.
I'm inclined to agree- anyone who tries aiming a drill or nail for that tiny gap between the two safe zones probably deserves to hit a cable
My objection to it has nothing to do with safe zones - that's a different issue.
It is simply that cables coming out of a ragged hole in the plaster and then wandering off to appliances and accessories is just plain nasty.
Surely there's no need to chase cables into the wall where it can't be seen though?
Neatly clipping or placing in trunking would be just as acceptable.
If the floor was solid, horizontal chases in the wall would be difficult to say the least to achieve safe zones.
Personally I prefer any surface cable to be behind fitted cupboards rather than appliances as it's less likely to be seen, but if done well it hardly matters.
By this I meant in some cases the only option is to run surface cables under the worktop, where safe zones cannot be achieved - for example a solid floor. I'm not suggesting cables should be buried out of safe zones.
Of course there is.
The latter would do when you can't chase horizontally, but not the former. And a ragged hole in the plaster will still not do.
Yes it does.
How about neatly filling round the cable?
No ragged holes behind my kitchen units - even re-painted walls before new units went in.
Do you mean you couldn't clip a cable to the wall horizontally in the void between the floor and the bottom of the base unit?
