Show us todays job.
Status
Not open for further replies.
just the perspective of somebody not an expert on wood who's only ever worked with European oak from Jewsons, I always thought American white oak was similar in appearance
Almost impossible to tell the two species apart from a couple of samples - I used to have to put chalk marks on them to distinguish in the offcut racks. One way to tell was that American tended to be resawn with circular saws whereas European tended to be resawn with band resawn.
The colour range and grain patterns can overlap so it’s really hard to be sure… have a look at oak veneered MDF, it’s always American White oak veneer, but the colour range can be pretty broad
There is a vital difference in its make up though, American White Oak has longer and open cells which means in our damp climate it’s not a durable material externally.
Over the years I varied buying American or European for internal stuff depending on price and quality at the time. American always used to be cheaper but that changed in recent times.
Are they the ones that are slow to 'warm up' ?
IIRC, yes, but it was almost 40 years ago and, as I was in my mid-teens, I cared not for the finer details :ROFLMAO:
It was a few quid to wander around in the sunshine, instead of no quid to wander around in the sunshine (y)
I fitted some upvc overcladding on a turn of the century cottage down in Charlestown, original woodwork was fine but owner wanted to do away with the need for re-painting. I was amazed at how the original woodwork was so sound after 120 years, pitch pine I think, and yet houses built in the 70's and 80's the wood can have all but rotted away.
We have what I suspect are steel lamp posts which have been galvanised. They're less than 10 years old and rusting quite badly.
Yes that is about the lifespan, we X ray test ours every 5 years from date of install for corrosion, it is mainly the bases on the older ones that tend to rot, the newer lights are treated and some have a plastic ring. Corrosion is the second biggest enemy for the lifespan.
Status
