Hi
I've currently got installed an 8.5kw shower, on 10mm wiring clipped to the inside of stud walls. It's on a B40 MCB with a 30mA RCD. The stud walls may have some sound deadening material in them from what I can see, and the cable run is around 10m.
The shower has started to misbehave and not heating correctly, and I would like to upgrade it if I can to a 9.5kw shower. The new showers I've looked at all specify what I currently have as a circuit when the cable is within an insulated wall, so I don't believe the circuit needs to be modified.
I've read the wiki on Part P notifications, and I'm still not sure if this is notifiable work or classed as minor since I won't need to modify the circuit?
Andy
Andy
