ah but if you run in front of the train and nearly match it's speed, then jump to avoid getting a shock as the train touches you, you would simply stick to the train and not get squished.. there will be little or no transfer of kinetic energy to you..
All conductors connected to Line or Neutral are considered as "Live" so since the "Earth" wire is connected to neutral at some point all wires are "Live"!
Umm something seems wrong there!
But however daft it may seem with the exception of a bathroom shaver socket outlet most metal in the home is either connected to the electric supply or so small not to matter.
So long as it is all connected to the same point then the only problem would be when entering of leaving the house. In the same way as when there is a tram crash you should jump off the tram not step off it.
Once one uses more than one appliance from an isolation transformer then with the exception of Class II and III equipment you need an earth system to reduce chance of a shock or fire.
Thanks for all those very informative replies. So, from what everyone is saying, it seems it is 100% safe to sit in a bath full of water and touch a tap that is live?
You're right, I do "feel" it. I know it may not be logical. But it's counterintuitive that it's safe to touch a live source when you're soaking wet. Are you saying it IS safe then? Would you do it? I'm genuinely interested to know, not trying to score points, and I appreciate all the thoughtful input so far.
Surely that steel band will tighten onto something square just as well as round?
I suppose I'll have to drill a hole in my filing cabinet though, and bolt an eyelet to it. Do you think the drawers will get a good enough connection via the runners, or should I fit some flyleads?
