Isn't that scenario why there are limits on fault loop value so that the protective device on the Class 1 electrical equipment will operate before the touch voltage becomes high enough for long enough for it to be a risk to most people?
Bonding the tap to the wiring earth doesn't entirely eliminate the problem but it does help because the fault current now has a second route to true earth through the bond wire and the tap
In fact the wiring earth the socket supplying the failed equipment will be at the same potential as the case of the equipment so the tap bonded to that wiring earth will be almost the same potential as the case . ( a slight differenc will exist due to volt drop due to fault current along the flex ).
So tap and appliance at same potential means no shock.
One fault that often appears in bathtub failures is a transformer melting its bobbins due to a shorted turn and thus bringing some part of the mains winding into contact with the core.
