Nice day down here, and Mrs Dave54 was using the ride on mower to cut the grass. I thought I'd do the odd bits that I usually do with the brush cutter, and had a sudden thought about the Tecumseh engined walk behind mower that belonged to my late mother in law.
So I dug it out from the back of the shed, thinking to myself "Waste of time, it hasn't been used for at least 5 years". So there was oil that appeared to be oily and reasonably clean. Petrol long gone of course. Tipped some petrol in, pumped the bulb. Pulled and I thought it fired. Pulled again, and sure enough it ran! I had to pump the bulb a bit to keep it going at first, but it settled down to a nice rattle, and I proceeded to cut the bits of grass.
Now I know the oil needs changing, and I know I'm going to have to de-gunk the carb, because it sometimes takes it on itself to stop, which I'd assume is crepe in the carb, and it seems a bit down on power sometimes, OK at others.
One thing I'd like to know though, and the point of all this. I've had the carb apart before several years ago to try to cure the hunting problem the engine developed. It cured it for a bit and then it came back.
Any ideas what's causing the hunting please? It's very pronounced, on then off.
