Texecom Premier Elite fault light, no power to key pad
remove red core + from network in on the expander in first picture, power is provide by fly lead
wrt to power, your adding power with the fly lead from the PSU to the expander in that PSU box.
other network devices can be split from the Panel and from the PSU, but need to make sure you keep within the power limits for each part.
for the sets can I just solder the wires togethera and then wire them in as one as its quite the faff trying to put them all in
I have no idea where you get the soldering together from my post.
First get things right before doing anything permanent
when you put in the wires into the connector - the hole with the screw on - it is very difficult to ensure there is a good connection for all 4. would you recommend using a waygo wire connector to first ajoin the wires together and then have a single leading out into the connector?
Thank you to everyone who helped out. The additional psu and improved connectors fixed all faults. All sensors are fully operation .
