- Joined
- 11 Jan 2004
- Messages
- 43,933
- Reaction score
- 2,884
- Country
If you are going to spur off a circuit above only a "cowboy" would choose the lighting circuit.
Now you're just being ridiculous.
My loft has no socket circuits in it, but it does have a lighting circuit. How do you think I should power my aerial amplifier?
(Clue: a suitably labelled 13A socket-outlet)
1. Yes.Anyway this has all got acrimonious needlessly.
It seems:
Have I managed to correctly sieve out the pertinent facts from the arguments?
- I can have sockets in the bathroom if they are a certain distance from "zone 1" (which I need to look up)
- I'm not sure about hard-wired as opposed to plug-in sockets, what the rules are there
- I can even just run my TV off the lighting circuit even if there is debate whether this is a good idea
- A special bathroom TV, or protecting my TV from the moist air, is a good idea (but not required)
Why does Winston's house only have one lighting circuit? And why is having to reset the breaker such a terrifying prospect to him... many people have this happen every time a bulb blows!?
It got acrimonious because when any of us advise (correctly) that a 13A socket can be used on a lighting circuit, somebody who, AFAICT has no training or qualifications spits his dummy out of the pram and calls those of us (who are trained and qualified and have decades of experience) who might dare to do this "cowboys".Anyway this has all got acrimonious needlessly.
Indeed, but the distance is 3m, so no good unless you have an enormous bathroom.It seems: I can have sockets in the bathroom if they are a certain distance from "zone 1" (which I need to look up)
The main rule that might catch you relates to switches. If the TV had an accessible switch, there would be restrictions as to where it could be located. Hard-wiring as such is not a problem.I'm not sure about hard-wired as opposed to plug-in sockets, what the rules are there
You can, and may. Bear in mind that, in terms of the 'debate', there is only one (albeit vociferous, with strongly held views) person on the 'no' (or 'not advisable') side. Even he has had to admit that it is explicitly allowed by the Wiring Regs.I can even just run my TV off the lighting circuit even if there is debate whether this is a good idea
Indeed - but, as you say, that's 'your problem' and not related to any 'requirements'A special bathroom TV, or protecting my TV from the moist air, is a good idea (but not required)
It seems so. Well done!Have I managed to correctly sieve out the pertinent facts from the arguments?
I didn't start anything. I made a perfectly acceptable suggestion. You took umbrage.
Is that suddenly my fault?
Now you're being even more ridiculous.
I didn't say it was not allowed. I said there was never, ever, a reason to do it.
Here is the list of devices considered suitable for use as fixed lighting points:What we don't need to do is encourage it with unsuitable sockets ....
For some reason, just as with his blathering about Low Voltage and electronic transformers, it is abundantly clear that the site wants him to do it.It got acrimonious because when any of us advise (correctly) that a 13A socket can be used on a lighting circuit, somebody who, AFAICT has no training or qualifications spits his dummy out of the pram and calls those of us (who are trained and qualified and have decades of experience) who might dare to do this "cowboys".
It would appear you immediately mistook this as an attempt by me to compete against you as to who had the higher qualifications.those of us (who are trained and qualified and have decades of experience)
