not used
wrong.
not used
Have you read any MIs for extractor fans recently?NO. FCUs are not used or required on lighting circuits.
I'm not suggesting that it's sensible, but ...!! You can argue that FCUs are not 'required' because of the MIs, but they most certainly are 'used' - because of the MIs.
Kind Regards, John
My loft has no socket circuits in it, but it does have a lighting circuit. How do you think I should power my aerial amplifier?
(Clue: a suitably labelled 13A socket-outlet)
That's a fair bit better than saying that they are"not used" - which is ridiculously incorrect. However, "should not be used" will, to many people, imply some rule/regulation - and I need not tell you that no such rule/regulation exists.Let's say FCUs are not required on lighting circuits and should not be used.
As someone pointed out earlier, that wouldn't stop someone fitting a "5A" plug to their welder/whatever. In fact, if I look in a dusty corner of my cellar, I might even be able to find you a "5A to 13A adapter", so you might not even have to change the plugA 5amp round-pin socket and plug.
Let's not.Let's say
That's all very well, but it's of little use to the OP whose question/problem related to getting power to a TV in the bathroom.... 5. Use an aerial amplifier that is phantom powered up the coax from a power supply behind the TV. ... No.5 is by far the most common method with no.6 a close second.
To say an FCU should not used on a lighting circuit is a bit ridiculous.
Someone already pointed extractor fans supposedly need 3 amp protection.
It's not unheard of that a security alarm can be found on a lighting circuit. Here an unswitched fused spur (3 amp no doubt) would generally be required, often by the MI, and to act as some form of local isolation, as a switch could be accidently switched off.
You say "supposedly" but that implies that actually they don't.Someone already pointed extractor fans supposedly need 3 amp protection.
Do you, and everyone else, think it appropriate that such a demand should be classed as "manufacturers instructions"?It's not unheard of that a security alarm can be found on a lighting circuit. Here an unswitched fused spur (3 amp no doubt) would generally be required, often by the MI, and to act as some form of local isolation, as a switch could be accidently switched off.
Winston - I didn't notice that in the six pages of whatever all this is.
You do, indeed, keep saying that, but you nevertheless seem to have a problem with a circuit wired in cable with a 16A CCC being protected by a 16A OPD, if it happens to be called a 'lighting circuit'.As I keep saying the fuse is to protect the cable not the appliance which should be internally protected.
