- Joined
- 25 Jul 2022
- Messages
- 18,967
- Reaction score
- 1,625
- Country
Yes. There are other advantages though.Loss of economy of scale for logistics is the obvious disadvantage (15 minute cities).
It's got very little to do with climate change, that's not why they are being introduced.Yes, to help with climate change
But will only be used by those that specifically want or need to go there.Yes, to help with climate change, you can drive out to the ring road go around the ring road and back into another area of the city, which might be a few hundred yards from where you started.![]()
Yes, most people only travel when they specifically want or need to go somewhere.But will only be used by those that specifically want or need to go there.
Not sure they are the right answer to the issues, but not many alternatives being put up by the nosiy objectors.
I wish the world was that simple, but it isn't.If most of the population want to walk or cycle then there should be no need to restrict car use to force people to do so.
Agree with all of that. I also agree that 15 minute cities which promote walking and cycling are a good thing, they should create an environment where people want to walk or cycle. If the 15 minute city idea is implemented properly then people will only want to use their cars occasionally, there should be no need to restrict car use.I wish the world was that simple, but it isn't.
It is obvious that if there's a nice pleasant footpath then you're more likely to walk than if there's a muddy path by a 50mph dual carriageway.
It's also obvious that you're more likely to cycle if there's a safe bike path instead of that 50mph dual carriageway.
The physical environment makes a difference to your transport choices. It's silly to assume otherwise.
You travel on many buses ?Where do the criminal element fit into this with their nefarious ways of wanting your watch and bike.
Going by bus can be a bit of an experience in our cities, long gone are the days when a sole nutter jasper carrot got saddled with are an exception to the rule, now it seems the sane ones are an exception to the rule.
