Vaccine questions - Is the vaccine definitely as safe as the other vaccines?
Status
Not open for further replies.
Thing is G. I knew the risks of DVT when/after flying was around 1 in 1000. Same as I know it’s around 1 in 3000 for women taking the pill.
You have to copy & paste from google & then throw insults pretending to be more knowledgeable. Your views are worthless because most of the time you are just using someone else’s work. Try educating yourself instead of insulting others. It might make you a happier person.
How does 1 in 100,000 compare to other types of vaccines?
The experts are now saying that there is a 1/1,000,000 chance of dying from the AZ jab after the experience of 20,000,000 jabs administered. So those other 999,999 under 30s now have to accept an alternative jab which has very much less applications and risk feedback.
The risk of my daughter suffering a blood clot when taking a contraceptive pill is 1/1000 - Where is the outcry over this?
Is there any sense to this madness.
The experts are now saying that there is a 1/1,000,000 chance of dying from the AZ jab after the experience of 20,000,000 jabs administered. .
If it varies with age and gender, there can't be a simple one figure risk.
So when you found out about DVT incidence -was that from someone elses work or did you do the study yourself?
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Even when its pointed out you are wrong you can't help yourself.
It's from Nice. -Experts - but you don't like experts.
https://cks.nice.org.uk/topics/dvt-prevention-for-travellers/
Poor Dumb Dangee. Now go parrot the next anger issue from the DM.
Which jab are you referring to. Or just making up stuff.
G the quote you copied even states 1 in a 1000.
You really need to learn how to debate without behaving like a troll. People might take you more seriously.
The point is that you weigh up the risks = currently for anyone under 30 the risks of getting infected are less than the side effects of the AZ vaccine. But the side effects of using an alternative vaccine are less than the risk of getting infected.
Also stating the incidence of blood clots after taking the pill makes no mention of the type and severity of the blood clots so it's a pointless stat as its not comparing like with like.
You are such a liar. :ROFLMAO::ROFLMAO::ROFLMAO:
1 in a thousand airplane passengers get DVT.
The post quotes clearly.
The annual incidence of DVT is estimated to be about 1 in 1,000. However, the risk of developing DVT is increased 2-3 fold after long-haul flights (more than 4 hours)
From the quote you copied. Maybe if you’d managed to read it properly, you wouldn’t make yourself look so foolish again.
From the quote you copied. Maybe if you’d managed to read it properly, you wouldn’t make yourself look so foolish again. View attachment 229764
That only serves to prove you were wrong. You can put it up in lights but it doesn't back your point.
Gaslighting. lol. Bojo does it better than you.
Hmm both can't be true. But in Dangees world anything goes. :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
You are not very good at this. Having to use your brain.
The confusion is down to the relative risk increase and the annual period.
1/1000 over a year would be 1/365000 chance of developing a DVT per day. After a long haul flight that might be 4/365000, but the increased chance won't last an entire calendar year. If it were a single day that you have the increased chance then a single flight would give you an absolute risk of 1.003/1000 that year.
The stat for absolute risk are the simplest. If you're flying to Australia and back every week then you've got a 50% chance of developing a DVT after a mere 12 years.
Status
