No you are wrong.I'm 100% correct, but it's a massive climb down for you and Noseall. JonathanM had a read, got his head around it, in about 5 minutes. Why can't you.
Please tell me what happens if form HSA1 is not signed.
If 2 doctors are not of the opinion needed, what happens?There is no need to approve anything. The form is even called a certificate of opinion. Failure to sign the form does not make the abortion illegal. It's the forming of opinion that makes it legal. A judge is not going the hand a prison sentence to someone who failed to fill out a form.
Sec 2,3 of the act says the failure must be wilful and the penalty is a level 5 fine - that a pretty big fine potentially.
JonathanM hasn’t got his head around anything, he is trying a strawman just like you.I'm 100% correct, but it's a massive climb down for you and Noseall. JonathanM had a read, got his head around it, in about 5 minutes. Why can't you.
Nobody is arguing that two doctors are not required to form the opinion that the abortion meets the lawful criteria.
Literally nobody.
If you are 100% correct why do you keep avoiding this:I'm 100% correct, but it's a massive climb down for you and Noseall. JonathanM had a read, got his head around it, in about 5 minutes. Why can't you.
the number reached is now four - do keep up.Nobody is arguing that two doctors are not required to form the opinion that the abortion meets the lawful criteria.
Literally nobody.
So she needs 2 doctorsNobody is arguing that two doctors are not required to form the opinion that the abortion meets the lawful criteria.
Literally nobody.
All completely and utterly wrongno - he's trying to explain to the forum dumb dumbs the parts of the act that provide the exemption, the role of the doctors and the separate requirement for documentation which has nothing to do with sec 1.
Nobody approves the abortion. That is not their role in the abortion act. Signing the certificate of opinion, simply documents that they believe the criteria are met based on a good faith opinion.
It is easy to answer.
1. If the opinion was formed in good faith - the abortion is lawful
2. If the failure to sign HSA1 was not wilful - there is no offence.
Simple enough.. ?
That's Doctor Who, to you, laddie.who?
And if the failure to sign was deliberate ?no - he's trying to explain to the forum dumb dumbs the parts of the act that provide the exemption, the role of the doctors and the separate requirement for documentation which has nothing to do with sec 1.
Simple enough.. ?
Requirement for two doctors' signaturesThere is no need to approve anything. The form is even called a certificate of opinion. Failure to sign the form does not make the abortion illegal. It's the forming of opinion that makes it legal. A judge is not going the hand a prison sentence to someone who failed to fill out a form.
He's been shown up by a builder and a woman's magazine. Give the lad a break.MBK, it’s not our fault you are wrong,
