I imagine the vast majority of shart meters have not been requested by the customer.I highly doubt she would have asked for the smart meter.
The WAN connection is GPRS via GSM. Its the equivilent of having a mobile phone in the meter cupboard.
The HAN connection is 2.4GHz 802.11g. Again, the equivilent of having a wireless access point in the meter cupboard.
I guarantee that she was already basking in plenty of RF transmissions before the smart meter went in
On another note, we moved into a property that had smart prepayment meters in it. We immediately got them switched to credit meters. The new supplier did it remotely but ballsed it up because they switched the electric first, which had the modem attached to it. The new supplier didn't support the meters in our property so once the switch happened they would 'revert' to standard meters. As soon as they did it they lost communication with the gas meter, which stayed in prepayment mode until we noticed when the credit ran out. (I was away for work, Wife at home with 3 kids) We had no way of topping it up. You can only get emergency credit when it has a connection to the network. I had to explain to the new supplier what they had done. I went through about 5 CSR's before someone understood what I was talking about. To be fair to her she got a meter person out within about 4 hours. He was confused because it didn't have a key or card slot to top up
He swapped it for a normal mechanical meter.
A few weeks on I started to notice strange problems on things connected to the 2.4GHz wireless network. Random disconnections and slow speeds.
I got the spectrum analyser out and found the source of the problems. The bloody smart meter modem
It was scanning the whole 2.4GHz band and beaconing at full power on every frequency looking for other smart devices/meters and the 'Smart Meter In Home Display'
So I decided that as this was no longer a 'smart meter' installation I didn't need the modem
One seal cut (on the modem, not the meter) and cable unplugged and the modem was dead. The 2.4GHz interference stopped. I logged it with Ofcom.
Indeed. The standard speil is (anecdotally) that the supplier rings you up out of the blue and asks if you'd like this free meter that'll magically save you money blah blah. I actually got that from BG and took delight in (very politely) telling her that there were three reasons I didn't want them :I imagine the vast majority of shart meters have not been requested by the customer.
Doesn't need smart meters for fun with WiFi.Imagine the fun in high-density housing with people doing that, and everybody having a smart meter and at least one person switching suppliers at any given time.
Not hard at all.How hard would it be so that a Smart Meter did not need to be changed if you swopped "suppliers"?
As BAS has said, I gather that is 'to come'. However, given how much time it is taking to 'roll out' the first phase of (not-too-smart) ones, I wonder how many of the people worrying about them now will still be around by the time a second phase (of replacing the first-phase meters) has been completed?How hard would it be so that a Smart Meter did not need to be changed if you swopped "suppliers"?
Technologically very easy, I would imagine. However, would you trust your life to isolation by a box which you knew was subject to all sorts of possible (and not necessarily all 'known') 'remote control'?How hard would it be for Smart Meters to include a simple point of isolation, thus negating the need for the supply fuse to be removed?
Very easy - but they wouldn't sell !How hard would it be for router code to be written with a default of not broadcasting the SSID?
Indeed, it is "imminent" and I suspect they will start putting in SMETS2 meters quite soon. There are two components, well 3 actually, to getting this working :As BAS has said, I gather that is 'to come'. However, given how much time it is taking to 'roll out' the first phase of (not-too-smart) ones, I wonder how many of the people worrying about them now will still be around by the time a second phase (of replacing the first-phase meters) has been completed?
That does seem an eminently sensible feature and one has to wonder why it's not more common. As I type this, I'm waiting for the contractor working for my DNO to come and fit an isolator (and reseal the equipment). I'll post some pics later - the tails have an "interesting" arrangement, and there's a submain to a CU in the extension protected by just an RCD and the service fuse that I'm wanting to deal with. It's clear that while there's certificates for both CUs from qualified sparkys, there's been some DIY work that needs tidying upMind you, a meter does not have to be smart for that. My daughter's (non-smart) meter has a built-in isolation switch (but no remote control!). I gather it's probably only SP, but at least as far as BS7671 is concerned, that should provide adequate isolation for her TN-C-S supply.
I would say in theory the smart could assist looking after the elderly as one should be able to over the internet check if the central heating is running and the kettle has been used even when the elderly persons home does not have internet. I want to do this with my father-in-law, however to date have not got the access codes to do it.
i wonder how that will work with more than one system with them seemingly unable to be monitored by one systemFunny you should say that...
http://www.policyconnect.org.uk/wsb...benefits-uses-assistive-living-and-healthcare
