- Joined
- 17 Aug 2010
- Messages
- 2,889
- Reaction score
- 507
- Country
John, 'non-ohmic' is an accepted description of something where the resistance is not constant. Typically something like, say, a diode.
Oh alright then, I'll also order a B40 breaker.
Fair enough. However, despite what has recently been suggested, Ohm's Law always applies, even when resistance is not constant (i.e. when the relationship between voltage and current is not linear) - unless one goes to extremes and (as has been mentioned!) starts considering superconductors etc!John, 'non-ohmic' is an accepted description of something where the resistance is not constant. Typically something like, say, a diode.
If it's an old Wylex unit with plug-in MCBs, then it's unlikely a 40A MCB will be suitable, as a substantial number of those fuseboxes were only rated for a maximum of 30A per way.Yes I am happy to change the breaker and it's back piece
You have introduced a new factor, which had not previously occurred to any of us, by mentioning that we are talking about an old Wylex CU with plug-in MCBs. As flameport has said, many of those were not designed (or rated) for more than 30A per way, so it's not necessarily safe to be running a shower >7.5 kW from it at all. Those CUs do sometimes catch on fire if excessively loaded.Yes I am happy to change the breaker and it's back piece. I don't think I'll get an RCBO to fit the old Wylex CU, I like to live dangerously.
It is more terrifying using your preferred methods, not the ones suggested by the knowledge on here.I'm not disputing the validity of the advice, but you guys are great at rooting us DIYers to the spot in terror. Keep it up!
The OP states the current shower is rated "Supply 240V 9.5kW, Loading 230V 8.7kW" assuming the new 9.5kW shower is rated at 9.5kW at 240v then they are the same power.If you are replacing a shower with one that is higher rated, that is not like for like.
