With the cold weather and a close call with frozen pipes I had a 300w infra red bulb on an extension cable in the roofspace. I was hoping to wire said bulb permanently in the roof space but the only power up there is the alarm control box. In the downstairs fuse box the alarm fuse is 3amp and there is an isolator switch in the roofspace with a 3 amp fuse. Could I wire another switch out of that isolator switch and run it at 3amp
