My mate has an older version of that compressor in the garage - and running the grit blaster we can keep it running continuously. And no, you can't hear anything else when it's running !
Had "a few problems" to start with - specifically getting it to start. Of course, when it was new, it was "tight" so took more current to start than now it had "a few hours on it". But the design isn't great - if it's the same, then permanent capacitor 2 pole motors which My dad suggested have poor starting characteristics.
The issues we saw were that when cold in particular, the first motor would fire up and get up to speed. After a few seconds, the second motor fires up - and the voltage sags such that it doesn't run up properly and either the supply fuse blows or the overload trips. This is where the "poor starting characteristics" bit comes in - a switch start 4 pole motor would probably have started up fast enough to have avoided the problem.
This was running it from a 30A rewireable fuse - I'd say you'd stand no chance of starting it off a B32 MCB. The 30A cartridge fuse in the house got a bit of 5A fuse wire added alongside it in the holder to provide some discrimination
Someone from
Machine Mart came out to it, and fitted slow start dump valves. There's a T-piece in the line from compressor to non-return valve. The slow start valve p1ss air out until a certain pressure is reached - which in practice means the compressor is run up to speed - and thus unload the motor for a few extra seconds. That was generally enough except in the coldest weather.
One other mod it's had, the second compressor isn't unloaded when it stops. There's a solenoid valve which is powered up during the delay between first and second motors starting (pneumatic delay switch on the contactor) so it gets unloaded before it starts. This failed eventually - and as an alternative I fitted some plumbing so the pressure switch unloaded valve unloads both compressors - with a non-return valve in the tee so the first to start doesn't pressurise the second.
For the technically minded ... Live supply goes via pressure switch, then to coil of first contactor and common of the delay switch mounted on it. NC on delay switch goes to unload valve on second compressor, and NO contact goes to coil on contactor for second compressor.
The wiring isn't complicated, and it wouldn't be hard to rewire it so the second motor ran off a separate supply (and hence separate fuse).
