I should have explained in more detail.
Consider a 3-pin plug that reduces the voltage down to say 9v. It's usually a squarish block.
The lead from this 3-pin plug can sometimes come out from the top or the bottom. Just curious to know this should be so.
Yes stops people found it as a habit, although treading on the lead does a pretty good job of pulling the plug out.Read my post 5 especially: They never come out of the back supposedly so that one cannot pull plugs out by their leads.
That is NOT a "Plug".I should have explained in more detail.
Not necessarily, it could be simply a transformer with AC output, or it could be a conventional DC power supply with a transformer, rectifier and smoothing capacitor.That is NOT a "Plug".
It is a "Switch Mode Power Supply" - mounted on a "base" with pins which will fit into a socket (and, hopefully, leave room to operate the switch and utilise any adjacent socket.)
