I have bought an air compressor for my garage, which states it requires a minimum supply of 40A (it is not 3 phase).
At the other end of the garage, about 6m away, through the door and in the hallway, is the consumer unit, an old style one with BS3036 fuses.
I don't want to start running wires around, especially as the compressor will not be used that much, so what I was wondering is if I could have something like:
http://www.neweysonline.co.uk/newle...d-range/1051013020/ProductInformation.raction
on the end of the compressor, and have a plug wired into a suitable fuse and sited next to the consumer unit. That way I can plug it in only when needed.
1) Is the above a viable option, and are any of these connectors rated above 32A?
2) Is there any easier way to do this, or what would be the best way?
