Not always it appears http://www.diynot.com/forums/electrics/fan-wiring-with-pics-posted-whats-happening.352684/Fan wiring with pics posted! What's happening?
I was waiting to see a "if you don't know" post. But no. pleasantly surprised!!
Those are star delta links, .
No such thing exists , try google,please go back to screwfix no one will miss you here thats for sure
You're a dick
You're a dick
Post your qualifications here then
Twin and earth was rarely used for lighting if at all in the 50s and your a LIAR you aint seen it many times
You try and twist everyones posts when your the one posting misleading crap.
Well thats wrong a star delta motor wouldnt need any links fitted
Correct, but just to clarify slightly, a motor using a star/delta starter would not have any links fitted.
I'm struggling to keep up with the various conversations going on, but am I correct in thinking that if I reconnect the motor terminals in the star pattern and attach the wires as they were on the original motor then everything will be fine?
Twin and earth for lighting in the 50? They didn't have a cpc in the sheath in 50s lighting, good god, you're a wrong un![]()
I've seen plenty of houses with 50s or 60s wiring
My brother has just purchased a large inverter to run a decent size lathe, we're struggling to identify L1, L2 & L3 at the moment and haven't attempted to connect it yet. I had no idea that he'd need to alter the motor's terminals to delta, is this usual practice?
I thought star delta was used where you want a reduced start up current and reduced torque, usually around a third of that of DOL delta.
