Broadband and telephones
I was about to make that same point. When directly connected your laptop has a globally visible IP address and is open to port scans and all sorts of attacks.
I'm guessing you're just demonstrating that it can be done without a router. I'm also guessing that your usual setup is using a router (or some other box) to provide a Firewall in addition to the the one included wither your OS?
Yes, it's a quick way to prove if the router is a problem or the fibre line is a problem. I wouldn't run it without a router routinely.
I've been, and gone, and done it - ordered up fibre this afternoon.
After a lot of discussion with a fibre provision company. We are on Plusnet 40Mbps, FTTC including phone service, but no calls £25.72. I was offered 150Mbps NowFibre, for £23.99, 18 month contract, plus optional £3 for phone, with free calls evening and weekends, keeping my number - I can cancel the latter, at no cost, at any time.
The supplier has said the installation engineer, will work with me, to install the ONT and router, where I want it, in the loft, providing there are a couple of power outlets there - there are. If the engineer doesn't agree, I can cancel the installation without penalty..
Engineer is booked for next Wednesday afternoon.
Would that mean the Fibre would be on, and working during the engineer's Wednesday visit?
The fibre will come in from the pole - does that mean the copper wire would be completely removed, and replaced by the fibre, on the day?
Yes, the fibre will be on and working during the engineer's Wednesday visit. The engineer will test that you have internet as far as the new router that they will supply and will leave you with that new router working.
No, they won't touch the copper wire. No-one will remove it, it will be left in place indefinitely. They are also unlikely to cancel your existing Plusnet service. It is likely to still be working alongside your new fibre service until it is cancelled, you should clarify if it is your responsibility to cancel Plusnet.
The only thing that probably won't transfer on the Wednesday is your phone service. This often takes a while (perhaps a week or two) to transfer from the old provider to the new. The phone will continue to work over the old copper line until the number transfer takes place.
Thanks, that perhaps makes it even easier for me....
YouFibre, have written back, saying I haven't asked them to shut down my Plusnet account, in which case they would leave it to me to do that.
The way my copper goes, in via the eaves, then through the loft very low 'wings' is exactly the same way I want the fibre to enter, and so simply cutting the line and using it as a draw wire for the fibre, will make the whole job much, much easier.
