Yes. Thanks. Agree. Had I been asked for my opinion before it was installed, I would of said replace like with like. I.e. a conventional heat only boiler.
It is wrong on so many levels
#Required more pipework adaptions than if heat only boiler replaced.
#Oversized capacity
#Oversized physically (much larger than the old baxi heat only)
#Worse, still, it doesn't fit with the solar energy overflow going to the Hot Water tank, as it removes two sources of use, the downstairs bathroom and the kitchen.
#It is so silly, as the new bathroom downstairs has a bath and a shower and when that is used, there is also a tank full of heated hot water going to waste. Upstairs bathroom is the only thing fed of the hot water tank and it only has a shower and basin.
#The only rationale I could of accepted is perhaps for instantaneous heat at the kitchen sink as the boiler is very close, but still, not worth it for the downsides and compromises. And having plumbed the downstairs bathroom off the combi dhw out just makes a a very silly set up.
Also the controls he has, Nest, doesn't allow any modulation variation for flow temp as it is opentherm. It is aslo compromised by needing to heat the hot water in the tank to a safe level, so I can't see him lowering it below 64C. Maybe a whole new set of Vaillant smart thermostats may help but not sure it would be justified economically even now, especially when the nest was only purchased 18 month ago....
