Who says you can't have a light switch in a bathroom?
Have all the bathrooms you've ever encountered had the light switch outside them?
yup.... or a pull cord switch.
Would that be a pull cord switch working the lights?yup.... or a pull cord switch.
- There are no RCDs at all, so that doesn't comply with current regulations, and didn't comply when it was installed either.
Under the 16th the only things that had to be on a RCD was sockets likely to supply things used outside. As this is a flat (unless it's ground floor of course) then it's easily plausible that no RCD protection was required when it was installed.
You're right about the rest though.
An awkward argument there, when the sky 'engineer' arrives and you plug his extension in then that isnt protected, when you run an extension to vaccume the car, that isnt protected. Even if some are RCD protected then that doesnt stop the person with a faulty appliance or ext lead in plugging into another socket that doesn't trip out, therefore all sockets with the exception of ones behind fixed appliances should be RCD protected. Thats my interpretation of the reg mind.
is the towel rail fused else where?
Why?
Why?
Ease of use.
Can it go on the other side of the wall?
