Get lost I cant be bothered to read 3 pages ....
err how did you get to this "Page 4" then?
He was still on page 3 when he posted.
Obviously won't have read your question martin.
are you serious? You don't know how to do that?So how is one supposed to provide strain relief?
really?A blanking plate is a blanking plate
and
A flex outlet is a flex outlet.
how difficult do you think it would be to ensure that the cable coming out of 'the plate' has adequate strain relief?The work involved in making that blanking plate into a flex outlet proves this.
No strain relief
No connections
or possibly not.Possibly that centre hole is for making TV sockets by the manufacturer.
And the very shallow knockouts round the edges could be used with a flushed in box for fixed surface wiring, something like BT wiring.
there isn't one 'correct' answer.are you serious? You don't know how to do that?So how is one supposed to provide strain relief?
How would you do it?
I would fit a flex gland if running the cable through the front.
If I was lucky enough to find a flex small enough to go through a notch on the edge could maybe fit cable clips to wall or inside the box; only I wouldn't!
What's the correct answer, Mik?
mikhailfaradayski said:Who is to say that when a cable of a certain diameter is laid through a notch and then adequately secured to the wall on a standard back box, then the interference fit between the flex and the surrounding plate/wall combination isn't sufficient in itself
I wouldn't call that satisfactory.
In a place where no 'tugging' is likely, maybe. But otherwise, no.
Im not making a statment that it is ok, im saying to try it and see, then make your own call. (of course, this relies on a bit of experience and nous)
