The cable can go to one of the RCBOs with the busbar.
Yes - but, as I've just written, if one does away with the main switch (and uses that space for RCBOs), then how does one connect the incoming L to the L-busbar
Yes, I suppose so ... or one of the techniques illustrated by BAS.The cable can go to one of the RCBOs with the busbar.
It doesn't matter at all. As I said, I was just interested in know whether it was often done.No, I haven't but I can't see that it matters.
Very much so. You seem to have gained the impression that I have a problem with a CU not having an 'internal' Main Switch / Isolator, but that isn't the case - provided there is a nearby isolator.A main switch directly below would be obvious, wouldn't it? Especially for two small units, one above the other.
Oh, alright, sorry. It did seem like that.but that isn't the case - provided there is a nearby isolator.
The only thing I questioned was the practicalities of connecting the incoming supply to a CU which had no 'incomer device' (Main Switch or RCD) - but you and BAS have answered that.Oh, alright, sorry. It did seem like that. People don't usually question what they agree with.
You should know @JohnW2 well enough by now!always learningOh, alright, sorry. It did seem like that.
Are the terminals designed to be used with both?The cable can go to one of the RCBOs with the busbar.
Indeed. It's very often done to feed a second RCD, isn't it - in other words, it probably happens in virtually all 'dual RCD' CUs (including the several in my house).Being designed to use either one on its own does not necessarily mean that it can't use both at the same time. I can see no reason why it cannot.
Indeed not.Being designed to use either one on its own does not necessarily mean that it can't use both at the same time.
