So a non-condensing boiler with radiators designed to run at 60C flow and 50C return will be as efficient as a condenser with smaller output rads. Thanks again.
No because it has no premix burner (so air intake not regulated) and the fan doesn't modulate. Hence they are less efficient at part load/modulation. At low stat setting they simply cut out when set temp is reached but the POC's won't drop to dew point during firing as already explained.
