I was watching a USA YouTube video about using lead acid battery as a battery back-up. I have an old battery pack 12 volt 12 Ah which has a 300 watt inverter built in, and was thinking about a new battery, these cost around £20 and since lead acid (VRLA or AGM) can use a charger at the same time as using it.
The lithium battery (LiFePO4)
that replaces this, is around £200, now rated 288 watt-hours, so first need to turn 12 AH into watt-hours so 144 watt-hours so twice the size, but £200 so 10 times the price, but if buying the lead acid one now around £100 so really only twice the price, if I was not using some bits which I already have.
As they go bigger the price jumps, £1500 for a 2 kW model, and the battery to fit my solar system (3.2 kW) was £1100, and I can go to 4 of them so 12.8 kWh is my maximum.
As far as I am aware, I can't charge it off my car, but the small 12 volt Lead-acid I could connect to the car battery and run my car. We are looking at emergency power, not living off the grid, so fuel cost is not an issue, as we all hope it will not be used.
So the big question, "chest freezer, fridge, oil boiler and lights" what size is required? I am sure 2 kW is ample, but 500 watt likely too small, so at what point can one get away with it.
