Hi All
Just after some guidance so I am a bit more clued up about what I am talking about when I get my local Electrician round for a quote for the following work.
This is the diesel generator I have
http://www.pramac.com/United-Kingdom/en/soundproof-open-set-generator-p-6000s-1314.asp
used for back-up power via running a single extension lead to the house for a lamp or kettle boiling, but really at 6kw it could be used for a bit more! /?
SO I am thinking a manual changeover switch.
Given that the max 240V I have of this is 16A it is not like I could run the electric cooker or electric induction hob, or that I would want to.
I suspect mainly just lights and maybe the oil fired boiler/it pump, does this sound feasible?
From our meter tails, we have two main consumer units, one for sockets etc and the other for lighting, so one thought rather than powering all would be only to power the lighting section, but if we when into the main incoming and though our own intervention did not turn on high load appliances, this would give us power to sockets and mainly the boiler etc.
As for the switch I have see this one
http://cgi.ebay.co.uk/125-Amp-Gener...ls_Supplies_Electrical_ET?hash=item45f037ebda
Would I need 125Amps? Do I need 2 or 3 pole?
Don’t worry as stated above I am NOT doing this work myself, just wanting some independent thoughts to put to my electrician ( I know it is part P “Special location/installation”)
