Or other electronic items, I've had several builders ruin tool battery chargers by running off a genny.Running a modern TV off a generator is not a good idea, the output is not smooth enough, you could end up damaging your TV.
Wotan
Wotan
Why ruined?
Yes I have not personally had problems, although I have noted some generators are not good with droop or voltage regulation, but are within limits.Or other electronic items, I've had several builders ruin tool battery chargers by running off a genny.
Many many years ago we did music for a beach party using a 1.5KVA genny, basic set-up of 50W transister amp, tape recorder and a few coloured bulbs, nothing flashy but as the afternoon spread into the evening the music started sounding distorted, The amp sufferred and was sent back to the manufacturers (FAL) and they replaced the push-pull driver transformer but it , we put it into a local repairer who gave it a clean bill of health. We replaced it with a later model. It never did sound right again until I stripped out the output stage and replaced with commercial 50W module.Yes I have not personally had problems, although I have noted some generators are not good with droop or voltage regulation, but are within limits.
Only examined the first one I was asked to look at & several components on the circuit board were fried. Just did a sniff test on several others over time without opening them & they all smelt the same. Must admit I have not seen one for a few years now but I think most people around here know I don't do work anymore so I'm not sure if it is still a problem. But as Wotan & Sunray also feel it is a problem then it might be.Why ruined?
Except ...Loss of PEN is rare, but this could be reason for loss of supply, so PME/TN-C-S earth should not be connected to an earth rod.
Aren't even most of the small cheapy generators inverter based now? This should have improved output quality generally over some older gennies (in theory).Only examined the first one I was asked to look at & several components on the circuit board were fried. Just did a sniff test on several others over time without opening them & they all smelt the same. Must admit I have not seen one for a few years now but I think most people around here know I don't do work anymore so I'm not sure if it is still a problem. But as Wotan & Sunray also feel it is a problem then it might be.
a decent eg viktron sine wave inverters produce a smooth sine wave, ive put s scope on one.Do modern inverters provide a smooth sine wave AC?
Or a sawtooth?
Is that typical of a cheap off the shelf generator such as the man in the street might buy from from Aldi or B&Q?a decent eg viktron sine wave inverters produce a smooth sine wave, ive put s scope on one.
I've never looked at one.Is that typical of a cheap off the shelf generator such as the man in the street might buy from from Aldi or B&Q?
