Yes, they are called Flex-outlets or ones with switches are called - Switches.Do FCUs not exist as fuse-less?
I'm not even sure that it would achieve what you think it would achieve. It takes about 22A flowing continuously to blow a 13A fuse, and appreciably higher currents than that for shorter times.
The problem with that is that would require re-jigging of the circuits which isn't financially feasible. Take an example. One ring main powers a bunch of sockets only one of which I would need in a power cut (the fridge). There is another freezer which I also need but its on a different ring main.No. As has been said, if you are going to have a separate CU for generator-supplied things, the sensible approach is to only have that CU feeding things that the generator can supply (simultaneously) - otherwise, as has been said, there's really no point in having a separate CU.
It would blow if too much current flows through it. I don't want to see how the generator would behave - I would rather have the load reduced to zero by a fuse blowing.Nor do I really understand what you think the hypothesised fuse would achieve - a generator cannot supply more current than it can supply. If you tried to draw more current than it could supply, either the voltage would fall or, more likely, the generator would stall (stop).
Kind Regards, John
I appreciate your time to reply. However as I understand it a switch is a manual device that an operator can turn on or off.Yes, they are called Flex-outlets or ones with switches are called - Switches.
As I said, the generator doesn't really need the sort of 'protection' you are talking about. Unlike the National Grid which can provide an almost unlimited amount of current if large loads are connected to it, as I said a generator can only supply however much current it can supply (in practice, pretty little).It would protect the generator.
I obviously don't know what you would regard as 'financially feasible', but it would not be a massive job to install new sockets for just the fridge and freezer (and, presumably boiler etc.) fed from the 'generator CU'The problem with that is that would require re-jigging of the circuits which isn't financially feasible. Take an example. One ring main powers a bunch of sockets only one of which I would need in a power cut (the fridge). There is another freezer which I also need but its on a different ring main.
As I've said, you will not harm the generator by overloading it, and nor would any cable be at risk, since your 3kW generator could not provide enough current to harm any credible size of cable.It would blow if too much current flows through it. I don't want to see how the generator would behave - I would rather have the load reduced to zero by a fuse blowing.
Yes, but if it's a 3kW generator, there is no way it is going to supply enough sustained current to blow a 13A fuse.An FCU will automatically cut the circuit when the load flowing through it reaches a threshold somewhat higher than its rating.
You can put an MCB (of any rating you wanted) in a small enclosure but, again, I'm not sure what you would be trying to achieve by using it.A miniture circuit breaker (mcb) sits inside a consumer unit and does something similar but there is no fuse. I was wondering if there existed anything like that in a switch like form factor.
Indeed - as I said, I think you are being unnecessarily concerned.Yes, but if it's a 3kW generator, there is no way it is going to supply enough sustained current to blow a 13A fuse.
Thanks John for your advice and especially the line above which I hadn't thought properly about. Seems like I was overly worried about that.
Fair enough. As I said, I couldn't judge what you would regard as reasonably do-able (without too much hassle).However, regarding new sockets, it is obviously not an issue chopping in some sockets but the cabling to them would most certainly would be as would require plastering/tiling/painting and moreover would mean moving semi-built in fridges to access sockets behind during a power cut.
That's certainly what I do, but I don't know that I would necessarily classify it as "cheap and cheerful"My take on it is ... For a cheap and cheerful setup, just make sure your boiler/heating is using a plug and socket rather than hard-wired via an FCU ... That's my current emergency plan.
That is the obvious thing to do, and how I originally did it. However, I eventually got rid of that in favour of what you call the "cheap and cheerful" approach above. For a start, I didn't want the hassle of having to switch off circuits (or remember not to use certain loads) derived from the CU when it was genny-powered. More to the point, I have multiple CUs scattered around the house, which made the 'sensible approach' less than convenient if I wanted genny-power and genny-powered lights available throughout the house.Other than that, IMO the sensible way is a C/O switch between meter and CU, with a power inlet (wall mounted plug) on the other inlet to the C/O switch. That's what I plan to do when I get around to replacing the CU (part of the plan to get rid of the inconveniently located CU in the extension). But then you have to consider earthing and generator wiring ...
Do you have multiple supplies ? Unless you do, it doesn't matter if you have multiple CUs, you just put the C/O switch between the meter and "all your installation" - i.e. between the meter and where the tails/submains split to the separate CUs.More to the point, I have multiple CUs scattered around the house, which made the 'sensible approach' less than convenient if I wanted genny-power and genny-powered lights available throughout the house.
No, just a single 3-phase supply.Do you have multiple supplies ?
In theory, yes. However, although 4-pole changeover switches exist, they tend to be physically large and pretty expensive. When I used a c/o switch, I therefore put a DP one just in the feed to the CU serving most of the ground floor (including heating system), which obviously meant that the upper floors could not benefit from the genny supply, even for lighting. In any event ....Unless you do, it doesn't matter if you have multiple CUs, you just put the C/O switch between the meter and "all your installation" - i.e. between the meter and where the tails/submains split to the separate CUs.
That was probably the greatest issue for me. It's not just 'people' - on the upper floors there are things like immersions on time switches, which would have to be manually disabled if they were being fed from a CU that had been switched to a genny supply.I agree that managing demand could be an issue in some properties - particularly if there are multiple people, some of whom don't really understand how much power things use, or struggle with the concept of "don't switch on X". That's very much going to be a YMMV thing.
This is what I found, one generator had a tapping for earth bonding not neutral.This thread over on the Electrician Forum is "interesting" - in that it hilights the problem that there isn't any way to do a generic setup since there are interdependencies between how the genny is wired and how you need to wire the rest of the setup.
On the subject of which, I've encountered dual voltage (220/110V) generators which are 110V centre tapped to ground terminal but 55-0-165V with 55V between neutral and earth terminal. On top of that they are often a single pole overload device.We can talk about TN and TT, centre tap and earthed neutral, but what will the DIY person understand?
I remember on the Falklands finding a 110 - 0 - 110 volt supply, but the problem was the consumer unit did not have linked double pole MCB's in it, found same in UK with a system designed as 0 - 110 volt where the transformer had been renewed for one with an internal central tapped link to the frame, so again no over load on one leg, this resulted in whole machine needing a rewire after a neutral to earth fault.
