Why a 100A one if the load through it will be limited by the breakers downstream of it?you would need a change over switch ( 63A shown in link, you would need a 100A one )
Umm... yes, you did - sorry.in my original reply, I said to put it between the meter and the CU.. ( or at least I thought I did.. )
My genny is connected with a widow maker
Firstly, yes I know this post was created before Johnson's wife was born but its still valid technically I think.To keep things simple I would wire those items wanted during a power cut to a separate consumer unit. 2KVA is less than 13A and either you could used a 13A or 16A plug to feed the consumer unit and simply unplug from mains and plug into generator during the power cut.
Of course one can use change over relays and switches but really not worth it for 2KVA.
Much depends on length of power cuts but if you want uninterrupted supply then inverting to DC and back to AC is the way forward you can charge 12 or 24 volt batteries both from mains and generator and then use an inverter to supply the 230Vac supply. However this would only really be done where power loss was critical.
I have not had a suppliers power cut in years which would have damaged food in fridge or freezer and more likely to be caused by a RCD tripping if the food is that expensive then auto resetting RCD are on the market but at £300 each not cheap.
I have emergency lights and that is my limit can't see the time without power is enough of a problem to do anything else.
My son has different outlook and has an inverter and two large 70A 12V alternators on his engine. He has considered changing one for a 230Vac combined alternator inverter set-up where engine speed is not important but decided not worth the expense. He relies on the 300AH bank of batteries in the main the 4th 100AH battery being reserved to start engine. He runs everything from a 16A supply and intends to upgrade inverter to 3KVA but he expects to be away from shore power for days on end. But I also was able to run everything from 16A supply in a caravan and unless you use electric for cooking and hot water 16A should be ample.
The 8A available from a 2KVA generator will not run washing machine etc. But as temporary supply should be ample.
I'm not even sure that it would achieve what you think it would achieve. It takes about 22A flowing continuously to blow a 13A fuse, and appreciably higher currents than that for shorter times.So my Gen arrived today - its 3KW/. I've been thinking how to protect it and the cabling. The "normal" way would be putting in a 13a FCU so that if the spare consumer unit tried to suck more than that, the fuse would blow. .... The problem with that is it might happen rather often and I don't want to keep a supply of 200 13a fuses!
No. As has been said, if you are going to have a separate CU for generator-supplied things, the sensible approach is to only have that CU feeding things that the generator can supply (simultaneously) - otherwise, as has been said, there's really no point in having a separate CU.How do others solve this issue? Maybe a big box of fuses is ok.....?
