The word 'competence' again springs to mind.
If the OP has to ask the questions that he has.....on what is essentially a DIY forum - should he be installing back up generators.
I'm no expert on generator installation, but even I know the basics.
Generators come with three types of earthing 'arrangements' - dependant on their use.
As far as I can remember - without looking it up -
You can have a small portable generator with no earthing - bit like a class 2 - this would normally feed one or two items of portable equipment.
You can have a CPC connected to the neutral (at the generator) and run along with the 'Line' and 'Neutral' conductors........basically a TN-S......which sounds a bit like the OPs set up - but I think this earth is kept totally seperate from any other supply earthing arrangements (i.e. DNO).
And finally, you can have a similar setup to option 2 above, but with the neutral (at the generator) referenced to earth, via an earth electrode (a rod).......again, I think seperate from any other supply earthing.
I think the advice is to combine earthing if there are two supplies (e.g. two generators) operating equipment in close proximity.
You have to look at it as a seperate supply install and treat it that way.
I don't think I'm far out on what I've described - like I said, I'm no expert - but I think an electrician tasked to install two generators should have a grasp of these principals and not be asking on a DIY forum........quite scary, really.
