And why should the influence it has not be that it's protected by a 10A fuse externally as BS7671 itself requires if that's what the manufacturer says?
The appliance is part of the circuit.It's not to protect the appliance. It is to protect the circuit,
Should I start another poll, and see how many people think that that is a good and relevant observation, which clearly demonstrates the fallacy of my position, and how many think it is a stupid one?Better make sure that the manufacturer realizes he needs to make a Transmogrifier which can operate on anything from 1V to 1000V and anything from DC to well up into the RF range of AC then. We can't have him trying to "superimpose" his requirement that it be connected to a source of 240V @ 50 Hz on BS7671, can we?
There are many things which they can rightly specify to ensure proper operation and safety. Insisting on a particular level of circuit protection because they CBA to design their equipment properly is not one of them.Really, your argument is ridiculous. Manufacturers specify how equipment must be installed for proper operation and safety all the time - "That's how it works."
Can you explain what that means? It presumably cannot be true as a generalisation, since ultimately there will the 'most upstream device', upstream of which there are no other devices!All protective devices rely to some extent on the fault current limitation provided by upstream devices.
Yes you do.I just don't see what B-A-S is going on about.
Not a specification he is entitled to make. If he has made something whose internals need the protection of a 10A fuse then he must put that fuse in the internals.The manufacturer of some appliance specifies that it should be fed through a fuse not to exceed 10 amps,
The purpose of the fuse in a BS 1363 plug is to protect the flex, not the appliance.so in the case of using a BS1363 plug you put a 10A or lower BS1362 fuse in the plug.
Ib ≤ In ≤ IzI don't see how that is "superimposing" the manufacturer's requirements on BS7671 any more than saying that the device needs to be connected to a supply of 240V @ 50Hz, or that because it's rated at 1200W it needs to be connected to a circuit capable of safely supplying a minimum current of approx. 5A.
