better than the usual , I have a gas boiler and the pilot is not working, what is wrong with itYea, and ecotec plus comes in Combi, System or heat only versions, he later says its a 630 Which is a system boiler.
OK, looks like I (and maybe others) jumped to a conclusion that it's a combi. It must be a big house if it needs a 30kW system boiler. But it doesn't change anything about gas flow, pipe size and pressure drop.Yea, and ecotec plus comes in Combi, System or heat only versions, he later says its a 630 Which is a system boiler.
It doesnt.If that was also 30kW, it might give the installer a bit of a get-out
If it needed 30kw then yes, it would be a very very big house, but again, chances are it needs much less.It must be a big house if it needs a 30kW system boiler
better than the usual , I have a gas boiler and the pilot is not working, what is wrong with it![]()
Silly question, why would you think that?
There could be a very good reason why that power of boiler has been specified
Nevertheless, it changes nothing. the boilers running safe. so I'd not loose any sleep over it. If working pressure is lower than 13mbar next service with meter pressure still the same then you can assume there is a restriction building in the gas line.
Safe but not correct surely?
You won't be condensing at 65c return will you, nor will you have a working bypass?
(Unless it's not needed and has been locked down)?
I have the certificate-
Central heating mode
Burner operating pressure 20 millibar
domestic hot water mode
I’m confused. It’s not blank- there are some figures on it but to be fair I have no idea what they relate to and or if they’re correct.Yet your benchmark pic is blank ?
Had it had vaillant controls then you could select independent flow temps for heating and then higher one for DHW (or even lower for DHW and weekly legionella cycle)
