If you've connected the board like I mentioned above
Incoming neutral to main switch. Outgoing neutral from main switch to neutral bar 1.
You should have a neutral from neutral bar 1 going directly to RCD1. The outgoing neutral from RCD1 should then supply neutral bar 2. All final circuits fed from RCD1 should have their neutrals connected to neutral bar 2.
then the RCBO's will be picking their neutral up from neutral bar 1 via the flying lead. This is before the main RCD's so won't affect them.
Obviously the outgoing circuit neutral will be connected directly to the RCBO so again won't affect the main RCD's.
