I thought he was saying that you'd need to recover energy at a faster rate than that at which it had been used.I think bas is suggesting some energy would be lost due to not being able to store it in the battery quickly enough
He said that indeed, more than once, so presumably he had some underlying point about whether the battery could accept the charge that quicklyI thought he was saying that you'd need to recover energy at a faster rate than that at which it had been used.
That would be the least of your problems. If you had an infinite current you would need conductors of infinite CSA, otherwise you would get an infinite voltage dropSo that would be if you stopped instantly, so any braking force including infinity could be stored. The other problem would be having a motor/generator that could handle that.
Indeed he did, and more than once I told him that I didn't understand what he was saying.He said that indeed, more than once, so presumably he had some underlying point about whether the battery could accept the charge that quickly
If the only way you have to slow down is regenerative braking and you want to slow down at a greater rate than you can speed up, you have to be able to charge your battery at a greater rate than you can discharge it.I don't really understand that.
IMO the biggest problem I would have would be what would happen to my body when it was subjected to an infinite force.That would be the least of your problems. If you had an infinite current you would need conductors of infinite CSA, otherwise you would get an infinite voltage drop
Construct a theoretical vehicle, and assume a mass and a m/s² acceleration. Work out how much energy is needed to accelerate the vehicle to x m/s, and call it j.Indeed he did, and more than once I told him that I didn't understand what he was saying.
Indeed.I thought he was saying that you'd need to recover energy at a faster rate than that at which it had been used.
In one of Colin Kapp's Unorthodox Engineers short stories they had discovered a planet which had internal satellites made of collapsed matter. They wanted a surface transport system, but as the planet did not have a long life ahead of it (being, as it was, turned into swiss cheese by its satellites) they didn't want to invest in a proper infrastructure.(and if the journey finished at the same altitude as it started)
not necessarily back into the battery, you just have to store them somewhere. hence my capacitor suggestion, but other energy stores are available. You could lift a heavy weight up (some underground lines have the tunnels lower than the platforms for conservation reasons) or spin a heavy flywheel (I heard that used in buses once)have to put your j joules back into the battery
Oh, I see.If the only way you have to slow down is regenerative braking and you want to slow down at a greater rate than you can speed up, you have to be able to charge your battery at a greater rate than you can discharge it.
That may be a possibility.not necessarily back into the battery, you just have to store them somewhere. hence my capacitor suggestion,
I thought we were trying to make cars lighter?but other energy stores are available. You could lift a heavy weight up (some underground lines have the tunnels lower than the platforms for conservation reasons) or spin a heavy flywheel
https://en.wikipedia.org/wiki/Gyrobus(I heard that used in buses once)
In an emergency stop you need to be able to. In an emergency stop you need to be able to convert your kinetic energy back into potential energy at a faster rate than you are able to convert it from potential to kinetic.I presume that, in reality, one would not have a vehicle in which regenerative braking was the only way of slowing it down (particularly in the 'emergency stop' scenario you mentioned), but is it necessarily the case that "you want to slow down at a greater rate than you can speed up"? ....
Precisely..... even in the 'emergency stop' situation, the 'official' (per driving test!) stopping distance at 60mph is 240 feet, which I reckon (assuming uniform deceleration, which probably is not exactly true) equates to about 5.45 seconds - but I don't think your average car can do "0 to 60 in 5.45 seconds".
It would indeed.Given that the vast majority of braking is nothing like 'emergency stopping', I would imagine that nearly all 'ordinary braking' would be at a rate considerably slower than "the rate at which you can speed up".
Either that, or you recharge the battery at a faster rate.For those rare occasions when this ceased to be the case (e.g. 'emergency stops') one could (and would) presumably have some alternative strategy built in.
That being the case, the issue you were raising would seem to be very trivial in terms of the big picture.It would indeed.Given that the vast majority of braking is nothing like 'emergency stopping', I would imagine that nearly all 'ordinary braking' would be at a rate considerably slower than "the rate at which you can speed up".
