Agreed, but that's just the reason/explanation - and doesn't alter the fact that it is very much "in doubt"!It is only in doubt due to current levels of investment.
Kind Regards, John
I assume that's missing a sarcasm smileyDon't see why that's a problem. Surely all the solar panels which we paid people to put on their roofs will take up the slack?
I mean - they must surely be useful, or we wouldn't have paid people so much to have them, would we.
In the case of nuclear power, it requires both massive investment AND the will to do it. At present, too many politicians are still believing the greenwash that renewables will save the day as long as we roll out those rationing devices ... err I mean smart meters. Not to mention there being too many people still believing the "Nukular is bad" mantra without realising that the alternatives are almost certainly a lot worse. When you even find Greenpeace and Fiends of the Earth hippies supporting* nuclear then you know things are changing.It is only in doubt due to current levels of investment. If the Chinese can build cities of 10 million plus in a couple of decades and a whole high speed train network, we can build a better power network in 20 years. But it requires investment.
You haven't bought petrol, but you have bought 'fuel'!
Petrol = 46.7 MJ/kg Density is ~0.75 kg/litre so 35MJ/litre.
@£1.20 per litre including tax that is 29.2MJ/£.
The same amount of energy, but in electrical form = 29.2MJ Electric = 8.1kWh.
Depening on your supplier, if you do all your charging OFF peak on economy 7 that'll cost you 76p. On-peak £1.58.. per litre equivalent. A saving to be had only when your rate is less than 14.8p/kwh. (None of these figures account for the daily standing charge or 5% tax on electric) and that pushes the break-even cost further out of your favour.
But what of CO2? The tariffs above are from SSE, and so it's right to use their own declared 2017 figures for energy mix and emissions. 304kg/MWh = 304g/kw. Therefore for each litre of fuel you DON'T put in your hybrid car, SSE generates on your behalf 2462g of CO2.
Nozzle
Yes. SO WHAT??? Have I made any statements about how much it costs or how environmentally friendly it is? No, I haven't.
The discussion I was responding to was about the need to visit a filling station or find a charging point other than at home. Nothing to do with how green it is, where the power comes from etc., only about the need (or lack of need) for a network of fast charging points similar in size to the current network of petrol stations.
I think the one thing that puts me off buying an electric car is that I've heard the batteries need replacing after a relatively short time and that the cost of replacement isn't far short of the cost of the car. I don't know how true this is. Perhaps someone can put me straight.
Apologies if this has already been mentioned earlier, but this thread is so long I haven't had time to read through it all!
Transferable to new owners any number of times in that 8 years?Mine have a 8 year warranty.
Any onerous small print with the ulterior motive of reducing the number of warranty claims?
However, your residual will be massively reduced compared to something without that "expensive ticking bomb". I'd be very wary of buying something that's reliant on a battery that'll cost several times the cost of the car, and is known to have a limited life. I think most people would be much the same - hence the second hand value isn't likely to be much above the level of "cheap enough to scrap it when it dies" level.... and I'll be changing the car anyway.
Same here (as witness the 20 year-old car I am currently driving) - but with EV the amount being 'written off' over the life of the car is obviously likely to be much greater.I've always planned for the residual to be zero on any car I buy - ie I plan to write down the the entire cost. If it's not, that's a bonus.
Not only a larger amount, but (I suspect) over a shorter time as well.. with EV the amount being 'written off' over the life of the car is obviously likely to be much greater.
