No - it's a terrible example in the context of this question. Walking is a complicated business, involving gravitational and frictional forces, but ultimately you move in relation to the belt because of forces you apply to the belt.kendor said:the treadmill is a good example bas but you are missing the point again in what you have just pointed out, ie you mention the person running acting against the treadmill, this is the energy expended in order to keep stationary(the thrust) as you said but there is the answer, the person is stationary in airspace bar the up and down motion associated with running.
With the plane, it does not move because of any forces acting on the ground.
A WINCH AND AN ENGINE PRODUCE FORCES ACTING ON THE PLANE IN THE SAME DIRECTION!!!!!!!!!!!!!!!!!! FORWARDS!!!!!!!!!!!!!the winch analogy doesn't help the problem as that it is a forward acting force not a rear acting force propelling the plane
Yes, I agree.and doesn't allow the plane any backward motion, look at it this way the thrust is like a hand holding the plane from moving backwards do you agree the plane woul;d go backwards if their was no thrust but the runway control gear was set to moving, the wheels of the plane would be static and the whole craft would move backwards.
No - that's false.the thrust is what is trying to counteract this backwards force and because of it the wheels turn. now because the wheels are turning they are gaining ground ie the circumference of the wheel is being applied to the ground each revolution, if the ground was static the plane would move forward , the trouble is for every revolution gained the ground has shifted backwards the same, hence the plane in effect has gained no ground it is in exactly the same place it was when it started. no air going over the wings means no lift.
It would be true if the planes forward motion relative to the air derived from forces transmitted through the wheels, but it isn't.
I ask you again - in your model, what happens when a plane leaves the runway? If its forward motion depends on forces acting on the wheels, why does it carry on moving forward?
The answer is that it carries on moving forward because the forces acting on the plane have nothing to do with the wheels. So if they have nothing to do with the wheels after takeoff, they have nothing to do with them before takeoff, and it is irrelevant how the wheels move relative to the runway, the plane will still move forwards through the air.
OK - think of this - what distance would be measured if the surveyor was on an airport travelator, and walked along it pushing the device?Think of surveyors walking around measuring distance, they do it by pushing a wheel on a stick around, it's a physical thing, the mechanics of the wheel are a measuring device in effect.
No - that's the whole point - you are not on the conveyor belt, you are standing alongside it, feet on the ground.the cart example i'm not sure i agree with what you say about not being able to push it anymore from what you are saying i would be on the conveyor too?
Yes you could.if i was beside the conveyor standing on static ground then i could hold the cart stationary
But you are claiming that you could no longer walk forwards causing the cart to move forwards relative to the floor.
No - it cannot - it is impossible.but it's wheels would spin ever faster and i would expend more energy in trying to do so until eventually i could not balance the equation anymore same as the thrust on the plane there would be a time when the balance could not be maintained either the conveyor would give up or you would reach maximum thrust. but we are talking ideals here and assuming that both the thrust and the conveyor have no limitations ot that they both can attain the balance ie when the plane is at max thrust the conveyor still manages to balance the equation.
OK - what if the conveyor belt moves forwards, so that the wheels don't turn at all? Would you claim that the plane cannot take off because it is not moving?If that is confusing then forget all about the thrust and forces and just think mechanics, the wheel is a measuring device but in the example what is it measuring? distance travelled of course, on solid ground it would measure the distance it has travelled over this ground and as the solid ground is static it can be used as a reference, so you can tell by the amount of revolutions what distance they have travelled over the ground.
The conveyor is moving the starting reference has shifted you can only say the wheels have travelled over distance in relation to the belt but the physical effect only relates to the belt and wheels.
you as an observer standing on static ground would perceive the ground moving under the plane also the wheels turning but the plane itself would be static to you.
I don't know where the confusion comes from, - maybe you can tell us, as you are the one who is confused. The only thing I'm confused about is how to explain it to you.........maybe the confusion is coming from peoples perception that the wheels are somehow powered? they are freewheeling but the closed loop sensing of the system is looking at what speed these wheels are turning at and adjusting the conveyor accordingly. The only part that we can get a speed refence from regarding how fast the plane is wanting to move is the wheels, ie how fast they are spinning
