You may as well forget the friction...
..The brake systems on a jumbo jet have to absorb a colossal amount of kinetic energy.
After a large plane is stopped using full brakes, the brake temperature readings often redline for 5 or 10 minutes. It's not uncommon for airline crews have to call upon the fire department to check the landing gear.
The brake pads on a 747 can require up to three hours to cool down
That heat is in the direct vicinity of the hubs, bearings and wheel structure ... Could wheels spinning freely under reducing load induce such temperatures via wheelbearings alone? Nah...
Remember the thrust could move around 6,000 tons at a steady pace it'll cream 380 tons plus some extra friction.
Been trying to show why 228,000 lbs thrust hurles 800,000 lbs to 180 mph in around 10,000 ft on the ground ... and it does just that.
