ban-all-sheds said:
kendor said:
the way i read the question is that the plane will always be static as the floor moves.
How on earth do you arrive at that conclusion?
The plane starts to move as thrust is applied but then the runway matches the speed that the wheels were revolving at , so the plane eventually is static ie not moving through the air the planes wheels will revolve if they didn't then for a second the plane would go backwards until the runway sensed the change in speed of the wheels, whatever means of sensing whether tachometer looking at the wheels or some other means there will be a slight lag until the runway matches the wheel speed.
but whatever happens the plane should be relatively static in air space.
Explained ok?
