It bloody well is !!
If we were talking about the point at the centre of the wheels, and for every inch that moved forward the belt moved it an inch back, then it would not go anywhere. However, when talking about matching the speed the circumference of the wheels are going round at, then the plane can still move forward happily. Honest.
Here are two scenarios to imagine. Firstly the plane is sat on the runway with a cable going to a winch directly in front of it. Fire up the runway and the plane stays still. Increase the runway speed to as fast as you like and the plane still stays where it is, with no discernable increase in the tension on the cable, as the wheels are spinning beneath it freely. Turn the winch and the plane moves forward, even if you cranked the runway speed to compensate 3 x for the wheel speed.
Alternatively, imagine you are sat in a little trolley, on a conveyor belt, facing down a vertical slope (or make it 89 degrees if you are worried about falling off) - No matter how fast the conveyor goes upwards, nothing is going to stop you rolling downwards. Change it to an ice-conveyor and change the wheels to skates - same thing applies. Don't be fooled into thinking they have something to do with drive in either direction just because they are wheels.
In the first scenario the winch is equating to the thrust of the plane, in the second its gravity. Either way the plane is going to move forward and take off (and, lets face it, no-one would have bothered asking the question if it wouldn't).
