In the current cold weather our heating system isn't heating up the radiators furthest away from the boiler. I'm not sure if it has always done this and we are only just noticing it or something has broken?
We have a Vaillant ecoTEC plus 637 system boiler. I've had a look at the d40 and d41 values. Boiler had been off for a little while but was warm, set to heating demand only:
D40 D41 Time
59 53 0
64 58 4 mins
75 64 5 mins - Fan and burner noise increases
79 70 15 mins
Then turn off and go into over run
Then it cycles through
D40 D41 Time
64 60 0
79 70 1-2 mins
As the flow is reaching 80 I assume it is shuting down the boiler but why is it getting to 80? Is the boiler oversized and it's heating too quickly? Is the pump blocked?
What should I try to cure the problem before I have to call someone in?
D40 D41 Time
59 53 0
64 58 4 mins
79 70 15 mins
D40 D41 Time
64 60 0
79 70 1-2 mins
