Was the heating OK before you built it and added extra radiators?.
It was ok, but we basically replaced most of it. The boiler was replaced and moved to the loft, we added 5 rooms and replaced a lot of the old pipework. The system has worked fine since it was put in but we haven't had any really cold weather so it could have been cycling since it was put in but we haven't noticed.
Did you upgrade any of the existing pipes to allow for the extra load?
The new system comes down from the loft in 22mm and then is split into 4 sections of 15mm with 2-3 rads on each one. The longest section is the one that isn't getting hot enough and has 3 big rads on it.
Have you balanced the system? How to Balance a CH System
I've not used that method (don't have a pipe thermometer) but a similar one that balances the speed that the rads heat up from cold.
The lockshieds on the rads on the longest section are fully open and on the rest they are reasonable shut down. Is it overheating on the flow because the pipes on the longest section are too restricted and the rest of the rads are restricted through the lockshields?
If i turn off all the TRVs for everything except the ones on the longest section should I get them heating up and the difference to be 20deg?
