- Joined
- 27 Jan 2008
- Messages
- 25,303
- Reaction score
- 2,957
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
There is some debate as to if the cheaper consumer unit actually complies, I may seem daft, but retail outlets can sell you stuff you can't legally use, from electric scooters, two way radios, wood burning stoves and the list goes on.
So the problem here is what is the design date? The regulations have a date from after which any new design must comply, so if you smash a socket and replace it this clearly has not changed the design date, but adding a RCD must in my mind be seen as changing the design, so the design date is now, so it has to comply with today's regulations, however if there was already a RCD fitted and the consumer unit had been damaged then not changing the design so design date is the date original consumer unit fitted.
The design date is a bit open, as I could have designed a system in 2003 and could install it today without notifying under Part P, but I am sure the courts would not see it that way.
But in real terms we should be considering how the system is used and how safe it is in use rather than trying to find a way around the regulations, they were changed to include things like SPD because the equipment we use today requires that protection, and in the 90's before all these fancy consumer units came out, I fitted two RCD's to my house at the time as my 14 year old son had passed his RAE exam and was playing with radios as a radio ham.
However those two RCD's did cause problems, one was internal stair case, so no power and no light on the stairs, so fitted an emergency light on stairs, the second was having to go to garage to reset the RCD's. We seemed over the years to get a bout of tripping, it would happen every couple of days for a month, and even with all the test gear, could not find why, then 2 years and not a single trip, I think likely spikes from neighbour using a welder, but does not really matter why, what matters is it tripped, and over the years we have lost a few freezers full of food.
The more the circuits are split the less the RCD is likely to trip, and also the less is affected when it trips, it has said for some time now
Since you don't need to change the consumer unit, any improvement must be good, however I would not want a phone call from tenant at midnight to say the RCD has tripped and will not reset, and we have no lights, phone call kitchen sockets not working then OK they can wait a day or two while you get an electrician, but half the house out and that is different.
OK back when I fitted RCD's to my first house there were no single module RCBO's I could have used even if I wanted with the old Wilex consumer units, but today they are available, so every circuit can have it's own RCD protection (RCBO is a RCD and MCB combined) it is a risk assessment, what risk of loosing a freezer full of food, tripping over when lights fail, may not be seen as your risk, but it would seem you are a good landlord, so the electrician should explain the risks of not fitting an all RCBO CU with a SPD.
and one can argue since the RCD does not protect against over current it does not form a circuit, but we all know in real terms it does, so when this house had a new consumer unit it was an all RCBO unit, as I did not want to have to walk outside and down a set of steps in the dark to reset a RCD.Every installation shall be divided into circuits, as necessary, to:
(iii) take account of danger that may arise from the failure of a single circuit such as a lighting circuit
(iv) reduce the possibility of unwanted tripping of RCDs due to excessive protective conductor currents produced by equipment in normal operation
